Shrockworks Front Bumper UPDATE
Former Vendor
This is my idea/input for this design.
I really like this bumper ALOT, but i want my factory fogs.
Now, take that bumper, stretch it JUST and i mean just wide enough (but nothing extra) to put the factory fogs back in the bumper, but outside the frame rails...
Please pardon my mediocre Photochopping skills.
BTW, i really like the platinum/grayish color of your prototypes. It should be an option.
If you want a custom color, call. The anthracite (dark charcoal gray) color in the pics is a two step metallic, so it will be more expensive, but we can do it. If there is enough interest, I'll make it a std option.
Eternal ***erator
Have you been spying on us? I think you will like the wider version that is in the works now.
If you want a custom color, call. The anthracite (dark charcoal gray) color in the pics is a two step metallic, so it will be more expensive, but we can do if. If there is enough interest, I'll make it a std option.
Great minds mebbe? :toung:
I am very very interested in the design as you progress, please keep us updated!.
Like So:
and i would buy it!
Like So:
and i would buy it!
Eternal ***erator
That is a good idea. It might look good! Certainly no worse than anything i have seen to date. You couldnt go right to the top corners though (on the grill bar) or the headlamps would be blocked, it would have to attach lower, or be moved inward on the top horizontal bar...
I would lean closer to the inwards on the horizontal bar, though between the headlight and turn signal would be the other option. Horizontal bar would probably be the better position, but probably wouldn't look right. I know lots of people that run the radiator tube on TJ's untriagulated and have used it with no problems. Can someone photo chop a radiator/ winch bar in place.
Ron
Ron
In agreement
Like So:
and i would buy it!
Like So:
and i would buy it!
Eternal ***erator
Ron
Ron
Here is a quicky of the two hoops together (yes i know the winch is backwards, i mirrored one image to use with the other) I didnt try adding bars yet...
Former Vendor
We're working on a wider version, so the stock or other 4" lights can be incorporated.
Nick
Eternal ***erator
