shrockworks frame mounted rock sliders
Rubimon,
So, I have to ask. Why would you go from the shrockworks to the PJ? What was the advantage? I'm looking for pure function and don't really care about looks. The Shrockworks is attractive to me because it mounts to the frame. Any upward, or side, impact should be distributed to the frame. I need rock rails that will hold up to some serious abuse and work for a lift point for my hi-lift.
Thanks mcnaught6, it sounds like you have seen a few of these. Without actually seeing any of these in person it is hard to get a complete idea of them from pictures.
Pignajeep, you sure love the PJ stuff
I am not too sure how the new PJ body mounted sliders would hold up to the abuse the Arizona rocks can dish out. It is very easy to fall 2+ feet onto a rock ledge and one of those missteps onto the rock tube itself could have enough leverage to bend your tub. Just a thought.
Rubimon,
It would depend upon the type of impacts that may be encounctered.
Mild Whould be O.K. with body based protection.
Severe impact should be frame mounted protection.
Look at it this way-is your suspension on a vehicle like ours frame supported or body?
If you anticipate severe conditions I wouldn't want to transfer the potential shock loads through my body mounts to the frame they're attached to.
The descision in the end is entirely up to you but what is attached to the body other than the "creature comforts" e.g. the body itself?
How much clearance difference is there between the Shrockworks rock sliders and a tub mounted rock slider like ********** PJ sliders.
It looks to me that the Shrockworks will hang about one or maybe two inches lower than the factory rubicon sliders. Nick, if you are reading this maybe you can answer these questions for me.
Nick
Both PJ and Shrockworks are outstanding products. I have the Shrockworks Sliders because I wanted Sliders - I wanted my rocker protection to sit nearly level with the frame, so I could slide along the rock if needed and still protect my body. In addition, since the Slider sits 2" lower it works better from my Wife and Kids as a step.
I can tell you that you won't go wrong with the Shrockworks products. Jim (& Nick!) and Company are very good at what they do and take a great deal of pride in making the best product, period. Mind you, these are not "snap on" products, they do require some drilling and some time to install, but they are SOLID and the quality is second to none.
PJ, well I can think of 10 or 15 people on this board that run PJ rockers and I have seen WOL's rig in action and can say the folks at Full Traction (aka PJ) have really done a nice job in design and manufacture.
Bottom line is really think about what you're planning to do and what type of driver you are...
That's my 2cents.
It doesn't matter, because you're not losing any ground clearance. The Shrockworks rails don't extend below the frame. Am I missing something here?
