shrockworks frame mounted rock sliders
Old 10-27-2007 | 06:20 AM
whatroads's Avatar
Rubimon,
So, I have to ask. Why would you go from the shrockworks to the PJ? What was the advantage? I'm looking for pure function and don't really care about looks. The Shrockworks is attractive to me because it mounts to the frame. Any upward, or side, impact should be distributed to the frame. I need rock rails that will hold up to some serious abuse and work for a lift point for my hi-lift.
Old 10-27-2007 | 07:43 AM
mcnaught6's Avatar
Originally Posted by DCMP001
Thanks mcnaught6, it sounds like you have seen a few of these. Without actually seeing any of these in person it is hard to get a complete idea of them from pictures.
Pignajeep, you sure love the PJ stuff
I am not too sure how the new PJ body mounted sliders would hold up to the abuse the Arizona rocks can dish out. It is very easy to fall 2+ feet onto a rock ledge and one of those missteps onto the rock tube itself could have enough leverage to bend your tub. Just a thought.
my post is gone.
Old 10-27-2007 | 09:36 AM
DCMP001's Avatar
Hey, what happened to Mcnaught6's post? It was really well stated.
Old 10-27-2007 | 09:40 AM
Robar's Avatar
It discussed a blacklisted manufacturer and was deleted.
Old 10-27-2007 | 10:11 AM
Rubimon's Avatar
Originally Posted by whatroads
Rubimon,
I have wanted the PJ ones since I saw them in last years Orange Pure Jeep SEMA pics. (Can you believe they took that Jeep back after a period of time and crushed it ) The problem is they weren't going to be available for a while and I didn't want to wheel without protection, so I bought the Shrockworks which were my next favorite. Well, PJ needed a 2 Door Jeep to do a preproduction fit, and being the nice guy that I am, I offered to let them put them on my Jeep.(What a giver! ) Well, I happen to really like them alot (I would say LOVE but then my wife would get jealous); looks, clearance, the new added plate which gives me some splash guard protection, etc. I helped them install them, so I know how beefy they are. Plus there are crush sleeves through four different layers of metal and they feel like they were welded on. I cant say whether or not they would survue a 2ft drop on a rock or not because I haven't done it but I am not nervous about it if I ever get into that situation.
Old 10-27-2007 | 10:46 AM
101gargoyles's Avatar
Former Member
It would depend upon the type of impacts that may be encounctered.
Mild Whould be O.K. with body based protection.
Severe impact should be frame mounted protection.
Look at it this way-is your suspension on a vehicle like ours frame supported or body?
If you anticipate severe conditions I wouldn't want to transfer the potential shock loads through my body mounts to the frame they're attached to.
The descision in the end is entirely up to you but what is attached to the body other than the "creature comforts" e.g. the body itself?
Old 10-30-2007 | 09:22 AM
ToyFamily's Avatar
Former Vendor
How much clearance difference is there between the Shrockworks rock sliders and a tub mounted rock slider like ********** PJ sliders.
It looks to me that the Shrockworks will hang about one or maybe two inches lower than the factory rubicon sliders. Nick, if you are reading this maybe you can answer these questions for me.
The sq. tube sits below the pinch seam so you are "losing" about 2" there, and the round tubing is angled up. At the lowest point of the tube it is still 2" above the bottom of the frame. These are proven for their strength, the decision is up to you.
Nick
Old 10-30-2007 | 09:45 AM
Dayton's Avatar
Nick
I think you first have to decide on what you want? Do you want Rocker Protection? Or do you want a Slider? The difference here is PureJeep has a Rocker that sits higher and is body mounted for protecting your rocker panels from big rocks; while the Shrockworks slider is frame mounted, sits lower and protects the rocker, but also allows the driver to pivot and slide over rocks.
Both PJ and Shrockworks are outstanding products. I have the Shrockworks Sliders because I wanted Sliders - I wanted my rocker protection to sit nearly level with the frame, so I could slide along the rock if needed and still protect my body. In addition, since the Slider sits 2" lower it works better from my Wife and Kids as a step.
I can tell you that you won't go wrong with the Shrockworks products. Jim (& Nick!) and Company are very good at what they do and take a great deal of pride in making the best product, period. Mind you, these are not "snap on" products, they do require some drilling and some time to install, but they are SOLID and the quality is second to none.
PJ, well I can think of 10 or 15 people on this board that run PJ rockers and I have seen WOL's rig in action and can say the folks at Full Traction (aka PJ) have really done a nice job in design and manufacture.
Bottom line is really think about what you're planning to do and what type of driver you are...
That's my 2cents.
Old 10-30-2007 | 11:37 AM
tgrt's Avatar
Former Vendor
It doesn't matter, because you're not losing any ground clearance. The Shrockworks rails don't extend below the frame. Am I missing something here?
Quick Reply: shrockworks frame mounted rock sliders
