Shrockworks and a B.L?
I am looking to add rockrails/sliders to my jeep. I like the Shrockworks (they are my wife's favorite) but I am concerned about the body lift issue.
Do I have to decide whether or not I am going to do a body lift before I buy these rails?
I know when you order them they want to know if you have one.
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
![](https://www.jk-forum.com/forums/images/ranks/veteran_air_force.png)
I'd suggest calling Shrockworks to confirm this, but my understanding is if you don't have a BL, get the ones for without. They'll work once you install the BL with the previously described gap. However, the ones for with the BL will not fit unless you DO have the BL.
Due to the pinch seam, if you were planning on getting a body lift, I would get the ones that are designed for the lift, otherwise I don't think that gap will look pretty. Since it takes so long to get them with all the demand, I'd recommend just ordering them, and plan on getting and installing the body lift prior to them arriving.
I have a body lift, and ordered the body lift version, and am very pleased with them. I came full force down (after rear tire slipped) onto a rock and slammed on the driver side rail -- these are solid!!!
They are completely welded together, and snug up to the bottom of the frame, no option to change the height after install.
Former Vendor
If you are planning on getting a body lift (or have one) and you tell us you want that option we weld the sliders to the brackets farther up the bracket to retain the "stock" distance between our slider and the pinch seam. If you do order them as "Body Lift" they cannot be bolted on until you have the body lift on. One way around this is if you order them regular and end up getting a body lift and don't like the gap, just bolt on the stock Rubi sliders between which will fill it.
Nick
Nick
