Should this look like this?
Old 01-26-2009, 04:16 PM
jeepguyinMS's Avatar
Hey, I'm just glad you are getting it fixed.... it's worth a little ribbing...
Old 01-26-2009, 04:28 PM
JeepyJeep's Avatar
Default Ribbing
Worth the ribbing for sure...which I am going to set myself up for more of with this question.
When I hit the electronic sway bar disconnect button, what if anything can I see happen with the sway bar...I mean at what point on the sway bar does it disconnect from...well...whatever?
I had someone hit the button while I crawled under neath and I couldn't tell the difference between when it was connected or disconnected.
What should I be seeing...rib away!
Old 01-26-2009, 04:32 PM
BlackNorthernJK's Avatar
As far as I'm aware it actually unlocks the bar itself inside that big 'ole motor thingy you have mounted on it, so I don't believe you'll actually see much of anything, drive around on the road on some corners and you'll know if it's working
But....seriously....you had a shop install that like that ?? I'd be looking for a refund or something...and I'd be checking every other bloody part they touched
Old 01-26-2009, 05:32 PM
JeepyJeep's Avatar
Default Sounds right
Whew! I was hoping you would say that the disconnecting takes place there...if not, I would of had more problems.
Ya, I guess I should be pis#$d at the shop, but other than that mistake, bad as it was, I have not had any other issues...yet.
Old 01-26-2009, 06:19 PM
NE Wrangling's Avatar
It should take no longer than a few minutes to take it off and switch yourself. You should be able to do this especially if you plan to actually wheel it and go out on a trail.... just saying.
I beleive it's a 19 or 18 mm bolt. Tourque is only at 75 lbs...
Old 01-26-2009, 07:00 PM
Dylanjam77's Avatar
OUCH.... no likey that shop. If you did it being a newbie sure. A shop you paid money to do that making that kind of mistake!?!??!? OH my!
Quick Reply: Should this look like this?
