Should this look like this?
Ribbing
Worth the ribbing for sure...which I am going to set myself up for more of with this question.
When I hit the electronic sway bar disconnect button, what if anything can I see happen with the sway bar...I mean at what point on the sway bar does it disconnect from...well...whatever?
I had someone hit the button while I crawled under neath and I couldn't tell the difference between when it was connected or disconnected.
What should I be seeing...rib away!
But....seriously....you had a shop install that like that ?? I'd be looking for a refund or something...and I'd be checking every other bloody part they touched
Sounds right
Whew! I was hoping you would say that the disconnecting takes place there...if not, I would of had more problems.
Ya, I guess I should be pis#$d at the shop, but other than that mistake, bad as it was, I have not had any other issues...yet.
It should take no longer than a few minutes to take it off and switch yourself. You should be able to do this especially if you plan to actually wheel it and go out on a trail.... just saying.
I beleive it's a 19 or 18 mm bolt. Tourque is only at 75 lbs...
