should i be worried?
well im pretty new and ive search the forums..
here is my problem..today i installed my wheel spacers..set the jeep down to see the difference and there was!!! one of the wheels was even with the others ones.. take a look.
as you can see one of them is 3/4 inch and the other is almost 2 inchs?? are they suppost to be like that? also i notice this
the jeep is lump sided? and the sway bar links are mounted every other way!..not sure if i should bring it in and have them replace both my rear control arms to see if its even or what to do? the jeep is still under warranty.
any thoughts of what i should do would be great! thanks in advance
here is another one or 2 of both sides from a far
so a adjustable track bar will do the trick? i dont need to bring the jeep into the dealer and have them get new ones..they just look bent to me.. like the old owner did a 360 and bent one of the control arms or something
one more thing look at the sway bar links left and right are they suppost to be mounted like that both facing the same way?
ill have to crawl underneath tomorrow and take more pictures.
but like robar said i did set her down and looked and measure. the left rear wheel doesnt pop out as much as the other 3. ill take more picture tomorrow and post it so yah can see.. thanks for all the replys!
