Should I re-gear?
Old 05-26-2011, 04:24 PM
  #41
joe002's Avatar
Originally Posted by stendermac
...I have probably only driven 20 miles since getting the work done. couple more short trips, then off for a long road trip this weekend.
Thanks for the tips.
You going to get a chance to break them in before your long trip?
Old 05-26-2011, 07:50 PM
  #42
Sarathesahara's Avatar
Default stock gearing
So i was wondering, and im sure its a dumb question, but are the front and rear axles the same gearing? (im considering buying the 5.13's for front and back, but if they are different i would like to get the appropriate set) I have a 09 sahara, no wheels or lift yet, but would like to have better response when im hauling for work.
Old 05-26-2011, 08:06 PM
  #43
Bosox5's Avatar
Yep, when you regear, both axles must get the same gears. Buy the 5.13s for the d30 and d44.
Sent from my ADR6400L using Tapatalk
Old 05-27-2011, 07:41 PM
  #44
so what kind of change would i see if i were to leave the stock wheels on for a short time?
Old 05-27-2011, 08:05 PM
  #45
nthinuf's Avatar
With an automatic, you'll be fine.
From the charts posted earlier in this thread:
An Auto with 5.13 and stock 32's = 2687 rpm @ 70mph
A 6spd rubicon runs 2614 rpm @ 70 straight from the factory.
Old 06-08-2011, 11:56 AM
  #46
I am running the 4.10's and run about 1950 rpm @ 70mph stock sahara 18's would the rom jump be the same?
Old 06-08-2011, 12:21 PM
  #47
nthinuf's Avatar
I'm not sure what you are asking?
From the chart, an auto with:
4.10's and the optional 32" sahara tires (roughly 31" actual height?) would be at around 2150rpm @ 70mph.
4.10's with 35's (34" actual height) would be around 1950rpm @ 70mph.
Turning OD Off will bring the rpm's up to a more usable range for hills/winds/altitude/etc. To get that number, divide the OD On rpm's by .69
So, 4.10's with 34" tires = 1950. Divide by .69 = 2825rpm @70 with OD Off.
Old 06-08-2011, 12:36 PM
  #48
Awesome answer, thanks for the help!
Quick Reply: Should I re-gear?
