Should I re-gear?
#41
#42
stock gearing
So i was wondering, and im sure its a dumb question, but are the front and rear axles the same gearing? (im considering buying the 5.13's for front and back, but if they are different i would like to get the appropriate set) I have a 09 sahara, no wheels or lift yet, but would like to have better response when im hauling for work.
#44
#45
From the charts posted earlier in this thread:
An Auto with 5.13 and stock 32's = 2687 rpm @ 70mph
A 6spd rubicon runs 2614 rpm @ 70 straight from the factory.
#46
Originally Posted by nthinuf
With an automatic, you'll be fine.
#47
From the chart, an auto with:
4.10's and the optional 32" sahara tires (roughly 31" actual height?) would be at around 2150rpm @ 70mph.
4.10's with 35's (34" actual height) would be around 1950rpm @ 70mph.
Turning OD Off will bring the rpm's up to a more usable range for hills/winds/altitude/etc. To get that number, divide the OD On rpm's by .69
So, 4.10's with 34" tires = 1950. Divide by .69 = 2825rpm @70 with OD Off.
#48
I'm not sure what you are asking?
