Shortest 3" lift system?
#21
Thanks for the pic and input.
#22
Please look at this thread its $1500 and a complete system
https://www.jk-forum.com/forums/sponsoring-manufacturers-vendors-check-out-cyber-monday-specials-24/ome-jk-long-travel-suspension-lift-details-inside-67476/
The OME JK Long travel kit is finally in stock and ready to ship!
Here is what it consist of
OME HD front and rear coils
OME Long travel Shocks
Teraflex Front and Rear Bumpstops
Currie Rock Jock Sway bar Links Front and Rear
JKS Front and Rear Trackbars
Crown Stainless steel Brake lines
Currie Front Upper control arms
Currie Rear Coil Spring retainers
All this shipped to your door for 1499.95
This lift will work on 2 door and 4 door Rubicon and non Rubicon models. The lift will net approx 3" of lift and have A whole bunch of travel!
If you already have a OME kit and need the bumpstops we have them in stock and ready to ship also .
Thanks
David
Thanks
David
It seems for a 2 door you would need to add rear control arms also for the drive shaft pinion angle adjustment ?
#23
Thanks for the pics
#24
Good point, I only had a couple payments done when I cut mine off
These are the same shocks and springs from my Short arm kit, It sits the same height of course.
