shock relocation
shock relocation
Do any companies make a relocation brackets for the bottom shock mounts on the rear axle? They stick down way to far. They are just a few inches from the ground.
It think there may be a couple companies making some....I'll do a quick search for ya....
In the mean time, you can check out mine....my brother and I relocated mine awhile ago
https://www.jk-forum.com/forums/modified-jk-tech-2/modified-my-shock-brackets-tb-bracket-pics-18169/
You just need to make sure your shocks dont bottom out when stuffing a tire, and that your springs dont fall out when dropping a tire.
You can use the lower shock mounts that we make for the Rock Jock 60 rear end.
No pictures on our web site yet. Part # JK-BRKT-RSB sells for $19.95. You can weld them or bolt them on.
Do think any normal automotive shop could weld thoughs on or would you recommend a 4x4 specialty type shop? Also about how many inches does it raise them up I would like to do this with a BB lift and still use the stock shocks.
rock krawler was the first to make them i forgot one other. with all of them you need to measure the rear shocks for correct length.
Last edited by Robar; 02-25-2008 at 11:46 AM. Reason: Edited blacklisted manufacturer.
https://www.jk-forum.com/forums/showthread.php?t=18169
