shock lift question
shock lift question
I have the ome 2.5" lift installed just springs I just installed sway bar links and and removed the bottom bolt for the rear shock and noticed it only dropped 1" that's all I have left in travel not good so my question is which ome shocks should I buy to fit this lift long travel or the regular ome shocks.....not sure how long of a shock with out having my spring pop out or drive shaft issues on full flex.
Get the standard length for their 2" kit (not sure of the actual length, somewhere about 29" extended I believe). If you get the long travel you can pick up a set of spring retainers pretty cheap, and its not a hard install.
if ur doing the old man emu lift thats ome i assume u just buy the shocks with the same length
idk where u bought urs but whwere i see em u buy either the whole set or shock by shock and coil by coil if u did the 2.5 there is prolly 2.5 inch shocks to and if u need alittle more travel look in to some strong shock etensions liek the ones that the teraflex bb w/o shocks come with just put those wher ur shocksattach and it should give u some more hieght and travel with it
For daily driving no......if you flex alot then it is possible, but with just a 2.5" kit its not likley. I have the TF 2.5" coil kit with shocks for a 4" kit and dont have issues (2dr), I have spring retainers installed though.
