shock install
shock install
Easiest way to do a shock swap. GO! lol, no but seriously, im hoping i hear just jack up and swap, no removing tire and all that. I did my TF leveling kit, just dont remember how accessible theshocks were, thank you in advance.
U will about have to take the tires off. but that should be it. Just easier to go ahead and take them off got a lot more room to work with. what shocks did u get.
Damn, lol. ok, i got some eibachs from a guy here on the forum. said the ride was significantly better than stock, which i am looking forward to, lol.
Well for the rear you can do it without taking the tires off. I just used a 16mm (i think??) with a 3 6" extensions. Jeep was dirty and kept dropping crap on me so I didn't feel like twisting my arm up there and it was super easy with the rachet. The bottom bolt is easy as its right there. The shocks can be compressed with arm power for the most part.
For the front I would have to look again but can't imagine it would be easy with the tires on. I would take the tires off in that case and the top bolt is a bit time consuming as there isn't much room to go left/right. That one was a pain for me.
For shocks and not coils right? Leave it all on the ground, couldn't be easier. I swapped out my old shocks the other night for my new Elka's in about 1.5 hours. A closed end ratchet wrench will be extremely useful.... wish I had one
Unbolt them, put them up into the upper housing mounts and use your strength to compress the shocks until you can seat them in the bottom mounts. Start the nut on the upper mount till it's slightly snug and then use a flat head screwdriver to line up bottom bolt, push it through, tightnen the bolt and then torque it down. There is seriously no need to take off your tired or jack up the jeep....
