shimmy in steering
shimmy in steering
i have a 3.5 inch lift with bfg km2. my caster is about 6 , my tires are balanced, and i run about 28 psi. the wheel does a side to side movement. its not terrible and it does not do it all the time. it more of a pulsating movement although very slight. it is aligned with factory specs, could a little more toe in help? or any other suggestions thanks.
Are you running the factory rims or aftermarket ones? if they are aftermarket see if you still have those retaining clips (star washers) still attached to the wheel studs/rotors....They have been known to prevent the aftermarket rims from being completley flushed when installed which causes a slight shimmy to the jeep....Just throwing out some suggestions...Hope this helps....Best of luck...Thanks...
Had the same issue.... tried balancing beads, rebalance. Finally took it to a shop that knew what they were doing. The balanced the wheels to the rims then added weight. Run smooth as silk now. I gave the shope a nice tip for taking time to get it right, and I left my rig there all day so they had no pressure to rush the job.
