Shim starting thickness
Got an empty axle I'm regearing. It's a Dana 30 with the stock carrier. Putting 4.88s in it. Anyone know a good shim thickness to start with for the pinion and each side of the carrier?
What's the marking on the end of the pinion gear?
For carrier shims, Measure the housing opening with a caliper, then measure the carrier width with bearing races installed. Minus carrier from housing width for total shims.
That's a good idea, but I only have a micrometer and no caliper. I ended up just packing enough shims in until it was tight yet didn't preload the bearings at all. Is there usually a marking on the pinion to give a starting thickness?
It was a spare axle I had laying around. The pinion was blown and the ring gear in mine was blown so I swapped over the summer. I looked everywhere for the old pinion yesterday but I must have thrown it away. Guess I never thought about needing the shim thickness.
Smashboogie I'm at a total of about .2 on the carrier.
