Which shaft 1st
Pic 2 is the tcase end of the rear driveshaft, right?
And it is spitting grease in a ring that you can see on the undercarriage? (or run your finger around that joint to double check)
This means that that boot is already torn and is losing all of its grease. When it dries out, it will start making noise and then fail dramatically while you are driving on the freeway...
Pic 3 is the front driveshaft, right? It still looks good for now. (to me anyway)
My bad, I got the pics wrong. Yep, if that is the front shaft, and it is losing grease like that, it is the one you want to replace first.
That is what I had on the stock front shaft on my 4door, but I actually figured that the rear shaft would have the steeper angle on a 2door...
