Selonoid vs. non-selonoid winch
I don't want to start a comparison of winches or to hear this winch is better than that winch.....
I want to learn what the difference is between winches that have selonoids and winches that do not.
- Is one more reliable than the other?
- Does one allow for more frequent use - constant load, etc.?
- Is one more water/weather resistant than the other?
Appreciate it!
Appreciate it!
I have a Smittybilt XRC10 and I do not think it has any selenoids....from some of the posts on here people have opened them and looked at the 'control board' where the selenoids would be housed.
I guess I need clarification as to what a "selenoid" is when referencing a winch. Some old posts where they tore the winch apart to inspect it had commented that there were no selenoids just a small control board.
There are also "non integrated" and "integrated" selenoid winches. This would indicate that the winch has / does not have a separate 'box' that contains the controls. The newer winches tend to be integrated and not have the separate winch control box (Selenoid box). This may have been what they were talking about.
Anyone know the details of these that can educate me on this?
My guess would be that the solid state ones are not serviceable if they do fail. Or if they are, the'll be alot mor money. Regular solenoids are seviceable. But then again, I am no expert.
FYI - Here's the Warn 9.5si:
Solid-state (aka MOSFET) is superior to solenoids, but more expensive. I chose this winch as an extra protection against road salt. Other components, like the motor, gears, etc. are still somewhat vulnerable, but at least I don't have to worry about solenoids giving out (at the wrong time).
Then again... I added a 225A continuous-duty (600A surge) solenoid between the winch and battery. :-) If it was to fail, most likely it would fail closed, otherwise I'd have to take out the wrenches and connect the winch direct.
If I had a winch with solenoids, I might carry some spares. From what I've seen, solenoids are usually the part that goes first. I think most winches also use 4 solenoids (2 fwd and 2 rev) -- the cost of four GOOD solenoids (some are sealed better than others) can start to get pricey too.
js.
js.
Here is what a Smittybilt has - from the postings there are no selenoids.....
Is this a Mosfet setup or a 'unique' setup to Smittybilt? I didn't pull mine apart - these are images from another posting.
js.
js.
If you look hard enough you can fine solenoids with manual override buttons in case of switch failure.
If a solenoid fails you can take apart the solenoid in a pinch, file the washer using a rock put it back together and giterdone.
Mosfet fails you're screwed, it usually blows up shorting to whatever is close by and taking out everything in its path. With the ulta high amps of a winch I'm surprised any stand up.
I'm open to why they are supposed to be better though no matter how it sounds.
