Screw in wheel stud torque specs
Looking for some help from those who run chromo's. Just got my G2 rear shafts today which came dual drilled for screw-in wheel studs. Problem is, there is no info on torque specs to be found. Anyone have some insight into what I should torque 'em down to?
And don't worry, I plan to use some good 'ole red loctite during assembly.
they are a hex bolt that thread from the rear. I figured they'd back out first time I went to tighten a lug unless i had them set anywhere over the factory 95 lb's. Kinda stumped on this one
I'm surprised the shafts didn't come with instructions addressing this important point.
I would call the manufacturer and see what they say.
Yea that's what all my research is telling me. I run spacers so I really only need to get everything torqued down properly once, then its just maintenance.
I really wouldn't think much about it. Even if a wheel falls off, you still have three good ones left. Just be sure to turn into the direction of the side the wheel fell off
