School me on axle cs and gussets
Old 03-09-2013, 07:04 PM
jeepwave's Avatar
Default School me on axle cs and gussets
I am looking to strengthen my D30 up front with 4.88s
I am running 35s and want some extra insurance especially as I am looking into lockers this summer. I daily drive my jk but I do wheel it a lot...I would say pretty moderately ...occasionally pretty hard but def not extreme lol.
Someone school me . I'm a bit of a newb when it comes to axles
Also any reccommendations for kits?
Old 03-09-2013, 07:14 PM
loserhead4236's Avatar
Im about to get 4.88s and EVO sleeves and gussets for my d30. I asked the shop which kit they would recommend and he said he doesn't like to install anything except EVO. Not sure if there is a difference but ill take his word for it.
Old 03-09-2013, 08:17 PM
Former Member
BRUT4CE's Avatar
With a d30 grab what's cheap ie Terraflex sleeves, nitro, eco etc....
Nitro is a slip fit (freeze it bang ot in and done) the others are weld, drill holes in axle and slip sleeve in the weld it with the holes and outside where it we t in.
They are all the same no real difference unless you have a d44 front then run a nitro because it will allow 35 spline rcv axles.
I ran a d30 with c-gussetts, Eaton locker (has 4 pin design super strong) and it heldgood.
Rebel has a super 30 kit or if you build it then
Sleeves, lower /control arm gussetts, c-gussetts, diff cover, chromoly shafts....
Old 03-10-2013, 05:51 AM
jeepwave's Avatar
So basically I am looking for sleeves and gussets and ill be good?
Old 03-10-2013, 06:07 AM
jacksup's Avatar
sounds like what u are looking for
Old 03-10-2013, 06:19 AM
jeeperjkjeeper's Avatar
TMR makes nice beefy gussets...i have had them on for a year and they are solid
ID:	432008   Click image for larger version
ID:	432009   Click image for larger version
Old 03-10-2013, 06:37 AM
Former Member
BRUT4CE's Avatar
Yes. The sleeves keep the tubes straight you could also do an external gusset weld on , the c's have a bending issue so gussetting those keep it straight.
I would do lower control arm gussetts as well it just keeps those thin tabs together besides they are cheap.
Aside of that the rest is gearing, axles etc...
Old 03-10-2013, 07:28 AM
jeepwave's Avatar
Alright this makes sense to me. If I plan to get some new adjustable control arms I guess I better wait off on the gussets a for the LCA...currently I'm running the aev brackets for my arms
Old 03-10-2013, 07:33 AM
Murder¹'s Avatar
Artec makes a good kit its an outer truss with the c gussets & LCA skid also has a track bar bracket. I went with the truss because I read you can't run some chromoly Axel shafts with the sleeves in a d30. That's something else you might want to upgrade is you shafts go with any chromoly
Old 03-13-2013, 09:46 AM
Tripletsi's Avatar
I just had EVO c-gussets & LCA skids installed along with Nitro sleeves. You can install the front LCA skids now and not have to worry about your control arms, you just have to load the front into place then the rear, no big deal. I went with EVO C's because they are more streamlined than others and won't hang up on things. Then went with Nitro sleeves because of the labor involved in installing weld in sleeves. Froze them overnight and they slid right in. Then I welded the end to beef it up. Do your ball joints at the same time, it's well worth it. $800 Labor $400 Parts.
Be careful if you go with RCV's or chromoly shafts, that makes your Ring and Pinion the weak point on a D30. A shit ton more expensive to replace gears rather than an axle shaft...
Quick Reply: School me on axle cs and gussets
