sanding bedliner?
sanding bedliner?
Is it possible to sand spray on bedliner? I had a can of spray on not spay as smooth and you can see the globbing on my front grill.
That stuff is so rough I wouldn't know what grit to try.
I sanded some metal to get a couple runs out of the spray bedliner, not sure if there would be any difference on plastic. I used what I had lying on the bench which was fine grit, but since the bedliner is textured I think it will be pretty forgiving.
I just bedlined my PSC Brawler Lite and had the same issue. I lightly sanded the affected areas with 400 grit wet/dry sandpaper and resprayed it. You cannot even tell there was ever an issue!
Hope that helps.
Rick
Edit: noticed I said painted. I meant bedlined with the Duplicolor Rattle Can Liner.
Hope that helps.
Rick
