Sagging on right side !!
Old 04-21-2014 | 10:03 AM
mtnxr's Avatar
X2 I cured mine by adjusting the sway bar links....sounds a little crazy but it works for sure.
Old 04-21-2014 | 10:25 AM
RUBICON7313's Avatar
Yes , it came with new end links for the rear. At this point I'll try anything...thanks for the info.
Sent from my HTC One using JK-Forum
Old 04-21-2014 | 10:28 AM
RE , they are pretty good kits , right ?
Old 04-21-2014 | 01:07 PM
OH9JK's Avatar
JK-Forum Ambassador
Which kit did you purchase?
RE is decent stuff, typically a little more complete than others. US made product.
They used to be great but went through some hard times, folded and then was picked up by Transamerican Auto Parts (Smittybilt, Pro Comp, 4WP)
Old 04-21-2014 | 01:20 PM
3.5" super flex kit , and added front drive shaft , plus exhaust spacer kit.
Old 04-21-2014 | 01:34 PM
JAM85's Avatar
It's the Jk lean. I just live with it.
Old 04-21-2014 | 01:36 PM
OH9JK's Avatar
JK-Forum Ambassador
Are the rear springs bowing at all?
Old 04-21-2014 | 01:40 PM
They were until I put my control arms in.
Old 04-21-2014 | 01:41 PM
I thought I was gonna have to put correction plates in.
Old 04-21-2014 | 02:42 PM
SiliconTi's Avatar
Some sag, some do not. I did not notice it stock, as the Jeep is low to the ground and the eye does not catch it. I did notice it with a Rough Country lift - leaned about 1 inch to the right. I switched to an AEV lift (3.5") and I can only notice it if I actually measure it, and it is about 1/2 lean, but the eye can not see it again.
I researched this as it was driving me nuts, and it turns out some just come out of the factory that way.
Quick Reply: Sagging on right side !!
