running lean. ????
#31
What does Superchips say about running a CAI with the Wrangler tuner?
My exhaust burbles too. Sounds great.
Exhaust Burble on Deceleration
An exhaust burble, or throaty popping noise which could be likened to a babbling brook, is has a different cause if it only occurs when suddenly backing off on a vehicle's throttle. Essentially, the sudden easing off the throttle causes an immediate decrease in exhaust emissions to the degree that atmospheric pressure surrounding the exhaust pipe pushes cool air up into the exhaust system. This air collides with the warm exhaust gasses and creates a rumbling not unlike thunder. Normally this will only happen if the tailpipe has too wide a diameter to maintain equalized air pressure, or there is a seam in the exhaust pipes which is not air tight.
Repairs
Some people like having the throaty noise of an exhaust burble; some do not. For those who do not want this sound, there are ways of fixing it. For an exhaust burble on acceleration, the engine must undergo a professional tune-up including resetting the timing mechanism and lifters; keep in mind this will decrease high speed engine performance, but increase the quality of performance at low speeds. For exhaust burbles upon deceleration, the seams of the exhaust pipe must be sealed against unwanted air entry, or the pipe must be swapped out for one of a smaller diameter to maintain equalized pressure between exhaust and the surrounding atmosphere.
Read more: Exhaust Burble Causes | eHow.com Exhaust Burble Causes | eHow.com
Repairs
