Running 37s with a 35in spare
Old 12-27-2007 | 02:08 PM
LidLess07X's Avatar
Default Running 37s with a 35in spare
I am so on the fence about the 35s vs 37s thing. I have been looking at the Rampage rear bumper but they don't make a swingaway tire carrier. Honest opinions and flame away if you choose, but what If I ran 37s on the ground and a 35 for the spare. Rims and tires would all be same brand and style.
Is anyone else doing this? Rampage says you can get a 37 on the new mount they sell which moves your tire up and out but I know that is alot of weight and leverage.
Old 12-27-2007 | 02:46 PM
A'sJK's Avatar
You could really mess up your axle guts if you had to do much more than drive home cautiously on pavement.
I would err on the side of caution.
Old 12-27-2007 | 02:55 PM
Renegade's Avatar
A smaller diameter spare tire could also cause ESP issues if you had to use it. The wheel speed sensors would sense different speeds and possibly apply the brakes to the others to compensate. This is just speculation though...
Old 12-27-2007 | 03:20 PM
RAZORBACK's Avatar
Theres not enough weight difference going from a 35 to a 37 to worry about. Go with the 37' spare.
Old 12-27-2007 | 04:37 PM
kntr's Avatar
Originally Posted by putnam dan
Are you JOKING the 37's weigh a load more that 35's
Most are only 5-10 lbs more. You can check tire weights on tirerack.com
Old 12-27-2007 | 04:40 PM
bad63lac's Avatar
I happened to have the Toyo spec sheet on my desktop...
35 x 12.5 x 17 = 83lbs
37 x 13.5 x 17 = 93lbs
(The Toyo doesnt come in 12.5 in a 37)
So depending on if you're running a steel or aluminum wheel, we're talking ~110lbs vs ~120lbs total. I dont think that's a "load" more or a "joke" to say they are close in weight, though I myself am concerned about putting a 37" or even 35" on the stock carrier. Sure it will work but for how long...
Old 12-27-2007 | 04:48 PM
kntr's Avatar
Toyo Muds are heavy.
BFG KM2s
35x12.5x17---68 lbs
37x12.5x17---72 lbs
Old 12-27-2007 | 05:10 PM
Omega Man's Avatar
Originally Posted by A'sJK
You WILL really mess up your axle guts if you drive it like that .
Here fixed it for you.
Bottom line, if you can not afford to get 5 tires then you can not afford to get 4. It would be stupid at best.
Old 12-27-2007 | 05:22 PM
2K1TJ's Avatar
BFG KM2s
35x12.5x17---68 lbs
37x12.5x17---72 lbs
Where'd you find this? I looked on their site a while back and couldn't find it.
Old 12-27-2007 | 05:58 PM
kntr's Avatar
tirerack.com has a bunch of weights
