Rugged Ridge XHD -- What's it weigh and will I need a leveling kit
I'm considering an XHD bumper, ends, hoop for my 2011 unlimited sport. Curious as to what it weighs and whether I'll need some sort of suspension leveling kit (plan to add a winch as well). Anybody knows how much weight it'll add and how much sag to expect? Thanks.
Hold off
I have a two door (09), its almost 3 years old. No end caps and no hoop but I have a superwinch lp8.5 which probably equals the weight of what you want to do if not more. Bumpers relatively new so I haven't had any sagging issues yet. To get an idea have someone about 150-180lb stand on the front of you bumper, this will give you a good idea of how much sagging will go on. If you have a two door it most likely will be negligible that you wont need a leveling kit. Save your money and put it toward a lift kit.
EDIT:
Forget what I said (elnapaz), I reread what you posted and saw you have a 4 door plus plan to add end caps, hoop and winch, which will probably push about 200Lb +. It all depends on what type of winch. I really can only speak on behave of a 2door.
EDIT:
my RR XHD with a Recon 10.5K winch weighs about 130lbs.. no hoop yet..should be in this week.... no end caps either... my 2011 2dr rubi dropped 5/8" I don't really notice it ... I want to get some armor on before the lift.. then I can level it and all at the same time.
How easy was it to install the spacer? Any effects on ride/handling on the road? (Unfortunately, reality is that my Jeep spends 95%+ of its time on the road.)
It will sag. I have the bumper with the end caps, hoop and XRC winch. Mine sags in the front. The front spacers are easy to install. Jack up jeep, take off wheels, Undo swaybar links, undo brake line brackets and get slack. Undo shocks, drop front axle enough to get out springs, insert spacers and reassemble.
I may have left out a couple pieces. I was going by memory when i did my budget boost. Front spacers shouldn't take long to install at all.
Thanks everybody for the help. Just ordered a RR XHD with end caps and hoop from CES Offroad. Seemed the best price I could find ($539 + free shipping). Will hold off on leveling/lift decision until after I get all the accessories on it, e.g. rock rails (great advice, didn't think about that). Psyched!
