Rugged Ridge XHD Rear Bumper Install Issue - Help!!!
So I went into this installation figuring it would be problem free, but I can even get the bumper to mount to the brackets. With the bumper placed right in the center of the Jeep my mounting holes look like this:
![](http://www.deepskye.com/images/Jeep/Bumper/rearproblem01.jpg)
![](http://www.deepskye.com/images/Jeep/Bumper/rearproblem02.jpg)
Like the instructions said, I've left the mounting plate bolts untightened. What am I doing wrong here?
It looks like the holes are not lining up. I personally wouldn't drill ASAP. I would either contact Rugged Ridge or wait for another member to respond to this...
Drilling = RUST
Drilling = RUST
This sucks :/
This is a common issue on the rugged ridge rear bumper. Place a large philips screwdriver in one of the holes and pry til the other three line up. Insert the bolts and you're done.
I've installed 3 of these rear bumpers..... each one had the same issue.
It's gonna be a little rought for just one person to do it since you are also having to install the tire carrier brackets.
Definately do not drill!!!! It's not necessary....
a second set of hands to hold the bumper out and start all the bolts and draw them in togather
I WOULD NOT drill them out contact them and hace a new one sent out with a return "postage paid" lable (i hate when that shit happens)
![Don't Know](https://www.jk-forum.com/forums/images/smilies/z0tdntknw.gif)
I had the same issue with mine, I finally got so mad I was ready to drill, weld, anything to get the damn thing on there... I finally calmed down and took it to the guy that installed my lift, dont know how he got it on there but I am pretty sure he used the screw driver method that was mentioned earlier.
Same issue with mine. I had my wife and daughter pushing on the bumper while I started the bolts. Keep the bracket bolts loose. I installed the tire carrier later, and had to go through the same issue twice. Just don't try to thread the bolts in with things way out of line. I almost galled the threads doing so.
