Rugged Ridge wheels and back spacing
I was looking to run the RR wheels which I think have 5" back spacing. Can I run a 285/70/17 and not have wheel spacers? I think the tires are 11.2" wide and 32.8" tall.
i am trying to keep all of this info straight.
I would not think you would have any problems with that setup w/o a lift.
Maybe someone with the same setup will chime in.
You should have no issues at all, might need to do minor trimming on your front plastic air dam(fake skid plate) and rear pinch seam at full lock/flex.
There's a guy running RR wheels with 35/12.5's with just a 3/4" coil spacer up front and I believe he cut the rear pinch seam... No issues with back spacing.
I have RR with a 3" lift, fit great with stock flares, no trimming, if I had to do it again, I would've just done a tereflex leveling kit and fenders...
