Rugged Ridge Mirror Relo Brackets
Greetings all.
I have a 2012 jk r, auto.
Anyone use the RR mirror Relo brackets ? I was told that you cAnnot open your hard doors all the way with this setup. Is this true?
Thanks
Dj
Thanks
Dj
I just installed a set on my 12 jku. I have no problems with opening my doors. Only gripe I have is you really. Any see the passenger mirror without leaning almost all the way to the passenger seat. You can see maybe the far right 1/8 of the mirror from regular driving position.
I have them.... Doors work great! And like others said..... Passenger side is worthless unless the doors are off. Just installed a snorkel.... so i had to take the passenger side off anyway.
Originally Posted by dojohnso
Greetings all.
Thanks
Dj
Thanks
Dj
I run these and like all others have stated with the doors on the passenger mirror is almost useless, i have it adjusted to i can see the outer 2inches of it and use that..if its a problem add the small little round stick on mirrors to it if its really that much of an issue. my doors have never come close to contacting them either. The lil plastic sleeves are sketchy but you can trim them to fit properly just be careful when your tightening them down you don't strip the soft threads, i found out the hard way trying to get mine to seat prior to trimming the shims..
I have been running mine for a few years on my 07. I totally agree with the plastic sleeves being worthless. I think one was too big and one was too small. Since my doors only come off in the summer, I run the factory mount most of the time on the passenger door. There is very little difference when viewed from the front. The swap to the RR mount in the summer is very quick. My little black disk covering the factory hole started rusting after about a year, so you may wish to add some extra paint.
