Rugged ridge floor liners
They are the same mold as a few other "brand" labels. I have the quadratec version because it was cheaper, but they are the same and fit well. Find the cheapest (RR, quadratc, 4WP) unless you care about the logo a lot.
yea thats why i was asking. they are cheaper on e-bay than any of the other ones. just making sure they were the same.
1 Post
i bought the rugged ridge ones. the only flaw i found was that the hook that holds the mat in place fits up through a hole in the mat. while tight at first, the hole tends to enlarge and is no longer water tight. during the winter, water seeps under the mat and caused mildew problems. if you can secure the mat with velcro or some other way and keep that hole sealed. the fit and quality is very good though. I have the cargo mat too which needed to be cut for the sub, hopefully they sell one you don't have to cut now.
I have a set of RR floor liners up front. Right now the hook that holds it in place is almost too tight. I have to wiggle it so much to get it out, that I end up dumping dirt all in the floor. The sides of mine also buckle in slightly. Not sure what is causing it, but my friends do the same thing. If I can remember, Ill grab a pic at lunch.
