Ruff Stuff Toe Rod 2x LH
Just received my ruff stuff tie rod in the mail today. It is pretty damn stout. Removed the old one and painted it up and all was well until I went to thread the ends in. Both ends are left hand threaded. One went on nicely and I couldn't get the other side on. I couldn't quite tell if the bung was right hand threaded due to junk lighting but I'm pretty sure it is. Just wanted to see if anyone could assure me one side end if LH thread and the other is RH or if I'm just an idiot. If ruff stuff reads this I'm definitely not bashing you guys as my buddies and I use a lot of your stuff.
O.K., the GM 1 ton's where marked on them left and right. I did not look at the tie rod bar to close as to whether marked left or right. I just tried on each end till both fit. Will most likely be after first of year before I paint and mess with it! Good luck! It is beefy compared to stock.
