Rubicrawler
Rubicrawler
Just wanted to get some feedback. What do you guys think of the Rubicrawler. I wanted to order one for me Unlimited x because in first gear low range is just not low enough. They say it will half my current low range gearing. Any feedback would be great, it's less than half the price of a Atlas 4 speed.
Thanks.
Thanks.
Guys get all hung up on uber-low t-case ratios when the standard 3:1 ratio on the X is more than enough for normal descent and rock crawling work.
You can get salvage Rubicon t-cases for well under a grand, a superior choice given the two options you're contemplating.
If he's running bigger tires it'll help alot, especially cause he has a higher gear ratio. My only concern is the amount of torque it will generate on those axles. Either way it'll be a nice upgrade in a possible long string of them.
