Rubicon sway bar and disconnects
So when I got my rubicon it already had disconnects on the sway bar links. As I found out the sway bar had shat the bed. Seems to be a common thing from what I've read. I tried in plugging it and plugging it back in it is dead. The light just flashes when I hit the button. So I pinned up the disconnects and on even a lil turn and a wheel up say on the height of a curb my tire is rubbing on the links hard. I have 35s lifted and aftermarket wheels with more than stock backspace. What is everyone doing to keep the links out of the tires when disconnected. And what is the fix for the rubicon sway bar. I don't want to go stock but I don't want the stupid light on. I've read that there are tuners out there that can program that light off
Easiest is to use an EVO MG NoLimits manual sway bar disconnect. Cheap and works like a champ. You can turn the flashing light off with an AEV procal.
https://www.offroadevolution.com/pro...onnect-jk-jku/
Now with the manual set up installed and unlocked how much articulation is there is it conperable to being fully disconnected ? I never have the sway bar working properly to know how far it moves
Where did this piece of info come from? I've got a friend with RK 3.5" x factor/ fox shocks on his Rubicon and we got another 1-2" out of removing the sway bar vs just hitting the button. Links are parallel as they were from the factory and how they are supposed to be set. This was under full articulation, something along the lines of Metalcloak's CTI ramp but a ditch instead.
Perhaps a difference in the suspensions? I'm running RK springs (3.5" triple rate) and all control arms are Currie with Johnny Joints. Running OME LT shocks. ??
Here you can get an idea of how long mine are set...
