Rubicon or Sport??
Bc chromoly aftermarket axles provide an additional level of comfort when running 35s...37s...
... and these would offer more “comfort” still
https://www.dynatrac.com/axle-assemb...r-jeep-jk.html
While NO setup is “bulletproof”, chromoly after market axles with some additional help such as trusses, c-gussets, and u-joint upgrades will certainly be stronger and offer more peace of mind even if only hitting the rocks ONCE a year. And the aforementioned full axle swap will increase said peace of mind.
Check the price differences. Rubi axles will sell for a whole lot more than the 'give-a-way or salvage just to get them out of the garage' 30/44 combo, and take-off e-discos and the stock rubi tires/wheels seem to sell well. So if you can score a good deal on a rubicon, it just might make sense.
But yeah, go for a non-rubi, then add a rubi tcase or atlas if/when you decide you need one.
For someone that is mainly pavement, I'd say 4.88 is ideal for 37s, BUT, if you're going to wheel the thing lower is better....5.13. 5.38 is too low though unless it's just a trail rig that's towed everywhere. If you have a rubi TC, definitely 4.88 would be the way to go cuz that 4.1 TC gonna take care of your offroad issues. if you have the sport, then you'd want to go that extra bit lower.
Savvytravvy (07-29-2019)
[QUOTE=bkg;4346204]I certainly agree that the aftermarket axles would be stronger and offer peace of mind... but $10K+ is expensive peace of mind...
... that it is, no doubt. That’s why I’ve been weighing the options of sport vs Rubi. If the Rubi all thing else being the same is 5k more expensive than the sport. And the Rubi (in my opinion) would still need new chromoly axles front and rear. Re-geared. Cs. And trussed. So that extra 5k for the Rubi is now what, 7? 7+?. That makes the 5k saving for the sport that much more palatable Bc now that 5k has cut my new crate axle set price in HALF. And those axles will be stronger and more capable to boot.
If I bought new I would go Sport. Then I would do suspension, shocks, sway bar disconnect, gears (no more than 4.88 if you are running 37" tires) and lockers. That should eat up the difference between the Rubicon and would make a Jeep pretty much like a Ruby. Only other thing I would splurge on is perhaps an Atlas TC. The gearing would be a compromise as you say rocks only 2 or 3 times a year.
Assuming you'll go with an auto trans, to me, it depends on the trails you do the rest of the year. If you're always doing slow trails the Rubi T-case is ok. If you're doing more open trails or mud you'll want the sport t-case. I've only wished for a lower t-case a handful of times. I have friends that have changed out their 3.8 or 4.3 Atlas' for 3.0. Other friends have changed out their Rubi cases because they were in and out of high range too much.
On the bright side, you're already ahead of the game knowing that it's a waste of time and money to do all the "upgrades" to a 44 platform and expect them to live with 37's. I'm running 5.38's with 40's and I've never trailered it anywhere. I've also got the mighty 3.8 and a 4 speed, so I need that extra help. I've driven her to Moab 3 times now from Phoenix, taken her to San Carlos, Mexico (about 400 miles the other direction) and never missed a beat.
I've built 2 JK's similarly to your end goal, both Rubicons, both built myself in my driveway. If I were to do a 3rd I'd start with a bone stock highly optioned 2012+ Sport and add:
-Front ProRock/RockJock 44 Housing, Select-able Locker & Shafts
-Rear Regear 44 & add Select-able Locker (Its a very strong housing, a truss really isn't even necessary with 37's)
-Rubi 4:1 Tcase
-4.88's & 37's
-Rubi 4:1 Tcase
-4.88's & 37's
