Rubicon or save the money?
Posting here because the mods will be imminent!
Hello everyone. I am still researching and weighing my options prior to my JK Unlimited purchase in June. I plan to install the TeraFlex 2.5" lift and replace the factory wheels with 17"-18", as well as the tires with 33"-35". My question at this point is... Do I spend the extra money on a Rubicon for the upgraded axle and shocks since it is being lifted, or save that money to put towards upgrades? I plan on using it as a daily driver with minimal heavy off-road use. I dont want to skimp on the costs and lose street performance after adding the extra weight and height of the tires and lift. Also don't want to spend money needlessly!!??
Any thoughts?!?! ----Approx. $7000.00 diff. between Sport and Rubicon base MSRP. Approx. $3000.00 diff. between Sahara and Rubicon MSRP...
Thanks Very Much!
Scottie
Thanks Very Much!
Scottie
Get the Rubi, skip the lift for now. It comes with 32's. If you just want a bit more height, get a puck lift, they are all pretty inexpensive.
Mod later, and running 35's in the stock Dana 30 (Sport and Sahara) is no bueno unless you gusset and truss, so why not just buy the Rubi in the first place?
Thanks Very Much!
Scottie
Thanks Very Much!
Scottie
Sponsoring Manufacturer
Personally, I'd want a lot more info before I made a recommendation. Auto or stick makes a difference as does how the Jeep will be wheeled. Are you going to be in slow speed rock areas or high speed mud? Doing loose ledges where wheel speed may be crucial or technical stuff where slower is better? For a JK, a stick Rubi works well many places but an auto Rubi may be too low geared for some wheelin'.
Based on that statement, you will be very happy with a Sport or Sahara. Put the savings into parts. I'm not sure you need to extras on the Rubicon if you're not doing hard core wheeling.
You can only answer that question yourself. I'd say it will truly depend on how hard you wheel or what you want to do. I sure wish I didn't have a dana 30 upfront, it's been geared and locked. Oh well I guess I'll see how it holds up. If I could have a do over I'd get the rubicon, for certain.
If your going to wheel it hard, save the $$$, buy the X/Sport, upgrade it to Dana60 with the $ you saved. Then do the 60 in the rear later. other than the D44 front, Elockers and some other meaningless stuff it makes no difference truly. The rubi transfer case is lower also, but with new gears that can be compensated for also. I currently have the X and it is lifted with all kinds of toys added. The wife now wants one. I plan on getting her a Rubi due to it will never see over a 33 or 35 inch tire. the D44 will be fine for that. All my parts will be going to hers and then I am going to put D60's front and rear on mine and EVO lift
The only things I miss/want are the 4:1 TC and the Dana 44 in the front, but I can swap those in for next to nothing. However now I think I'd rather get an underdrive so I could have 2.72:1 (stock TC), 4:1 (underdrive) or 10.88:1 (stock + underdrive) low ranges. Had I bought the Rubi, I would have probably got a 2.7:1 underdrive anyways. The elec sway bar disco, lockers and wheels would be removed in favor of JKS discos, air lockers and the ProComps I have now.
$4500 for a PR44, $1500 for 5.13 gears and lockers, $1000 for a complete lift, trade the stock d30 for a nice set of wheels and 35's, or maybe a rubicrawler... you have one hell of a rig for $7000 more than a stock x.... just sayin.
