Rubicon Express 3.5" Standard
Has anyone used this kit? For reference:
http://www.quadratec.com/products/16300_60XX_PG.htm
If you've used this kit what's your review?
Cam bolts aren't great because once you do it it's there. You now have an oblong bolt hole for your control arms. So if you ever upgrade to say adjustable arms, you will have to weld washers over the holes to make them round again. They aren't the best idea if you ever plan to upgrade again. Also it is a set adjustment. If you need more caster, well that's all you can get.
That's right and as long as you keep on top of maintenance, you will be fine. Many people run them, so don't think they're all bad. However, if you ever want to run new control arms later, you have to weld the brackets. Cam bolts are just an inexpensive way to adjust castor, I just decided to spend a little more upfront, get adjustable lower arms and call it good.
