Rubicon 2dr suspension HELP
hi i want to use the electronic sway but i also want to lift my jeep and put some agrresive look of tires, fenders,wheels and bumper so what did you guys recommend me to buy to make my jeep look brutal but having in mind that its everyday use car, thanks a lot and if some day come to puerto rico visit me im in rincon
JK-Forum Founder
a lot will depend on how much you can afford to spend. optimally, i would recommend 3" of lift and 35" mud terrain tires. a complete lift kit with replacement adjustable control arms would be best but you can get by with just a 2.5" budget boost (coil spacer lift).
![Yup](https://www.jk-forum.com/forums/images/smilies/yup.gif)
thanks and what about my electronic sway bar, do i have to change it or can i use it ? and what brand did you recommend me thanks waldemar
as far as the sway bar goes, call David at Northridge. He'll look you up with longer end links for the rear and then you move the rears to the front. The whole goal is to keep your sway bar angle close to factory so it's not such a pain to engage and dis-engage
