Rubber floors for the JK
rubber flooring
The only heat shielding is by the bell housing on both sides. The reason I think they did it that way was the fact you can pull your drain plugs and just hose the interior out.
The rubber flooring is just like the carpet it covers the entire jeep. (No shielding no smelll!!!!) I was thinking about going with Linex but when the linex gets old it looks old and it is permanent!!!!
Its been quite some time since you've had these now and i was just wondering if they were holding up? any issues with noise or excessive heat?
rubber flooring
No problems with the rear compartment or the roll cage.
Its been a while since the install and the flooring is holding up great!!!
Installing the flooring is very easy and I would highly recommend this product. The clean up is very easy and the lining fits perfect!!!
Thanks,Tim
Thanks,Tim
