RPM with gear change
Remember it's the actual measured height of the tire diameter which you also lose the squish of the contact patch.
Having been in both Sweden and Brazil I think I would have let my imagination run a little wilder for an occupation.
Actually with all the math it takes to fly those big ass airplanes I think you're going to have a pretty easy time figuring this out.
Figuring all of this out is alot of fun! I'll be a little sad when I have all of the kinks worked out..... Probably, then I'll be fixin' things that get broken...
I haven't experienced this with other vehicles that I've actually measured, but obviously there is a good chance that this is the case. I'm basing my speedometer on my GPS, which was accurate prior to the gear change and accurate in other vehicles. I also timed my jeep using known distances. I'll measure when I get home for curiosity.
