RPM with gear change
Old 03-26-2009 | 08:46 AM
Lee's Avatar
Lee
Default RPM with gear change
What RPM are you turning at 60MPH with 4.88 gears and 35s? I'm turning 2500 RPM. I have the six speed transmission. I was turning 1900 RPM at 60MPH with the X stock tires.
Old 03-26-2009 | 09:39 AM
BaltChief's Avatar
Thats why I think I'm gonna go with the 4.56's....
Old 03-26-2009 | 09:41 AM
1stWaffleMkr's Avatar
I assume your asking because it seems high. I just had 4.88 put in and I run 35's too. I havn't done the math yet, I would rather just ignore the 10mpg average Im sure I will see after the first fill up. Wondering if I should of went 4.56. Oh well there in.
Same RPM as you.
Old 03-26-2009 | 11:01 AM
Lee's Avatar
Lee
Actually, I wouldn't have gone less. The anemic 3.8 needs all the help that it can get. I was just curious because in order for my programmer to indicate the right speed I had to enter my tire size as 33.
Old 03-26-2009 | 11:45 AM
scootrrydr's Avatar
You have to trick your programmer? What kind of programmer is it?
Old 03-26-2009 | 12:24 PM
bigbluejk's Avatar
Originally Posted by Lee
Actually, I wouldn't have gone less. The anemic 4.3 needs all the help that it can get. I was just curious because in order for my programmer to indicate the right speed I had to enter my tire size as 33.
you have some type of stroker kit or something?
Old 03-26-2009 | 12:45 PM
Lee's Avatar
Lee
It's just a procomp speedometer recalibrator. You enter tire size and and gears and it corrects your speedometer.
Old 03-26-2009 | 06:46 PM
Lee's Avatar
Lee
Same RPM as you
Thanks....
Old 03-26-2009 | 07:02 PM
Lee's Avatar
Lee
I was wondering whet the hell you were talking about.....Then I realized that I'm the dumba** that mistyped...... I did the same typo in another thread. To much work, I guess. I was in Sweden last week and Brazil now. Too many diferent tempuratures and time zones.
Old 03-26-2009 | 07:20 PM
JPop's Avatar
Remember it's the actual measured height of the tire diameter which you also lose the squish of the contact patch.
Quick Reply: RPM with gear change
