royal purple ATF
I read about someone who had a transmission problem and the Dealer said his warrantee was denied because his fluid looked like Royal Purple (he didn’t use Royal Purple). In the end he did get is transmission fixed under warrantee, but it was a big hassle.
From what I’ve read the stock synthetic ATF in the transmission is pretty good.
In Powerstroke's it's frowned on. The stuff is too slick according to some guru's. Some guys do run it though without issue. In my Powerstroke, I went with Schaffer's ATF. I'll consider Schaffer's in the JK when I get close to ATF change.
What is the deal with Schaffers? Is it better and if so why?
I truly don't know if it's better for JK's, Schaeffer's (sorry misspelled earlier) that is. Brian's Truck Shop (BTS) built my tranny for Powerstroke and recommends the Schaeffer's over Royal Purple. He specializes in my truck trannies and does A LOT of them. With my truck, I replaced the tranny and upgraded the cooler, along with Schaeffer's. Changing all that at once yielded a severe drop in temps, the cooler was the big source. I can say this though, I replaced my T-case oil with Schaeffers ATF in my truck, and it's quieter and smoother.
I'm too much of a chicken 5hit to change much in my Jeep (warranty sakes). I would definately read up on any fluid I swapped out regardless.
I personally would not replace the stock fluid looking for any sort of performance benefits. The servos, and bands have been soaking in ATF+4 since the day they were born. Changing the viscosity and thickness of the oil to something new isn't what the tolerances or parts were built to take when coming out of the factory. Shift points could also be altered. I would agree with the last post on that if changed, a void warranty and premature wear could be expected.
Just my
Just my
