Rough Country Rear Trackbar Bracket
Part #: 1166
http://www.roughcountry.com/jeep_jk_2perf.html
Down towards the bottom. I have the 2.5" coil lift i'm about to put on and was wondering if anyone had any experience with this bracket?
You will have a slightly offcenter rear axle. It would be better for you to get an adjustable trackbar rather than the bracket anyway. You don't need either for now.
Put it on mine as well, it bolts to the frame instead of the axle which from what I understand is better. People have had problems with the ones that bolt to the axle. You don't really need it but it's cheap enough that might as well.
