Rough Country Manual Shifter Adapter issues....
Old 03-20-2013, 04:04 AM
09jaykay's Avatar
Originally Posted by Deucefour
Yeah I understand that, but how did you get the shifter lever off originally. Not the knob or the boot, but the actual shifter shaft.
I just took the one screw out and it pulled right off.
Old 03-20-2013, 05:22 AM
Impagzzz14's Avatar
Just installed mine on my 07 JK and it slid on like a glove. No problem at all. I used the Rc 1.25" shift extension with the 2" zone body lift.
Old 03-20-2013, 05:28 AM
Impagzzz14's Avatar
To get the shifter off i had some trouble. I did my clutch previously and it came off real easy then, but was a pain this time. I used a puller hammer. Which is just a long metal pole with a slider on it. At the end i had a hook to put around the shifter pole and then slid the hammer a couple times and it popped right off.
Old 03-20-2013, 11:26 AM
Deucefour's Avatar
Ok I may have to get something like that, mines stuck like crazy! Plus I wanted to be sure they should just slide on and off once the screw is out. Good to know!
Old 05-27-2013, 12:34 AM
wxgs's Avatar
BAAAM bringing it back from the dead. What exactly did you use in the end to take the shifter shaft out of the transmission's? I tried hammering, vise grips and a screwdriver as lever and nothing. Can I spray PB blaster on it to see if it "lubricates" and comes out? I don't want to hammer it full force as it could damage the transmission itself.
Would this work? Slide Hammer - Great Deals on Slide Hammers at Harbor Freight
Old 05-29-2013, 09:51 PM
Deucefour's Avatar
What I did was use a C-Clamp. Ever pulled a pitman arm? Same idea. A pitman arm puller might even work. Here's how I did it....
Undo the Allen screw... Then replace it but only give it a couple turns. Then I put the clamp on it. One part underneath the shifter lever and the other on the screw head. I actually took the flat swivel piece off my c-clamp so the ball would stay in the Allen head screw (or is it hex screw?) because its a pain in the ass because of the weird angle. Once I got it tight it only took about a half turn and it popped loose. Hope this helps ya!
Quick Reply: Rough Country Manual Shifter Adapter issues....
