Rough Country Lifts
Old 08-23-2014 | 10:40 AM
HNTRJMPR2006's Avatar
Default Rough Country Lifts
Looking to get a 2.5" lift for my '14 JKU...what's the best kit under $1000? I was looking at the Rough Country and can't seem to find enough helpful reviews.
Old 08-23-2014 | 10:45 AM
nthinuf's Avatar
https://www.google.com/search?q=site...-a&channel=nts
Old 08-23-2014 | 11:08 AM
hair2831's Avatar
Most everyone here is gonna tell you that RC is garbage. I have their 3.5" series ii lift and I'm completely satisfied with it. I've had it on for 2 years now and it rides good and has performed well off road. Only things I have added to it are Rancho geometry correction brackets in the front and I added a Fox steering stabilizer. Other than that, the kit came with everything I needed and I haven't wanted for anything else since putting it on.
Old 08-23-2014 | 12:18 PM
MarbleheadGuy's Avatar
RC lifts do hold up well enough until about the 3 year mark. Then they do start to fail especially if you wheel often. They make good enough entry lifts but I'd recommend putting a little extra money into a better, longer lasting kit. Speaking from experience...I'd go with the OME HD kit which will get you around 3" or Rock Krawler anything.
Old 08-23-2014 | 01:05 PM
I only need a max of 2.5" lift. Which is better, a kit with shocks or a kit without?
Old 08-23-2014 | 01:51 PM
KCCO JK's Avatar
A kit with shocks would be better. With longer shocks, you can achieve more flex(depending on the shock). Also, the stock shocks are garbage anyway. Rough Country isn't the best, but I liked my old RC shocks better than I did my stock ones. Of course, I like my Bilstein 5160's far more than the RC's, but that is the difference between a 50 dollar shock, and a 200 dollar shock, lol.
Also, and this is just from my own experience, but RC lifts start to sag pretty fast. With extra weight and a year of hard wheeling, I was only getting 3 inches in the front, and 2.5 rear, from my 4inch kit. So my recommendation would be to go with their 4 inch kit and just let it settle, and adjust the leveling from their. I think this would make the most sense as you are in a JKU anyway, and would benefit tremendously from the increase to your breakover angle.
Old 08-24-2014 | 10:06 AM
I'm thinking of going with an AEV lift
Old 08-24-2014 | 11:11 AM
afalletta's Avatar
I've got the AEV 2.5" kit and couldn't be happier just installed my 35" Nitto trail grapplers and they got perfect and look awesome
Old 08-24-2014 | 11:40 AM
Did you do it yourself? How hard was it and how long did it take?
Old 08-24-2014 | 11:43 AM
afalletta's Avatar
Did you do it yourself? How hard was it and how long did it take? Sent from my iPhone using JK-Forum
Yea I did it by myself and had it on a lift and it took like 4 hours, if you get stuck at all the instructions are very detailed. Make sure you have a good tourque wrench because all the different components have different tourque specs.
Quick Reply: Rough Country Lifts
