Rough Country Budget Boost Question?????
Old 03-18-2014 | 07:59 AM
TexasReaper's Avatar
Default Rough Country Budget Boost Question?????
I have a 2012 2 door Rubicon that I have had a Rough Country Budget Boost on for about a year now and a buddy noticed it had a slight lean to the left in the rear. Upon measuring the jeep in numerous places we have determined the left passenger side is 1/2 inch lower than the right. I have inspected the stock springs, shocks, spacers and shock extensions and have not found any damage present that I can see. Any thoughts on what may cause the 1/2 inch difference.
Old 03-18-2014 | 08:03 AM
jrod250's Avatar
The passenger side is lower? Perhaps the added weight of the fuel is the culprit
Old 03-18-2014 | 08:34 AM
SabrToothSqrl's Avatar
Default lift kit
does this kit have springs? or is this one of the 2" spacer ones?
I had a Rough Country kit on my TJ years and years ago and swore off them then... jeep was not level side to side and front to back.
Ever since I go with better names...
Was the jeep level before the install?
might be a good time to upgrade that kit
Old 03-18-2014 | 08:57 AM
Yes it is the one with the spacers and shock extensions, I am using the stock springs and Rubicon shocks.
Old 03-18-2014 | 09:21 AM
jadmt's Avatar
JK-Forum Ambassador
google jeep lean or gangsta lean. it is common on all lifts and even stock.
Old 03-18-2014 | 10:48 AM
ROGUE JK X's Avatar
does it still lean when the sway bar is disconnected?
Old 03-18-2014 | 11:14 AM
Don't know, but my buddy noticed the lean on the way home after we had wheel all day doing some rock climbing and moderate to heavy off-roading. I wonder if a spring could have shifted/turned to cause the lean. I know for sure it was level before we went off-roading.
Old 03-20-2014 | 06:42 AM
I have checked everything that has been suggested so far, are there any other causes for the lean? I haven't removed the springs to check for any bending or out of roundness. Thoughts?
Old 03-21-2014 | 06:53 AM
ROGUE JK X's Avatar
The only thing I can think of is the spring may have got messed up some how.
Old 03-21-2014 | 07:05 AM
jadmt's Avatar
JK-Forum Ambassador
1/2" is normally and common. Been well documented many times.
Quick Reply: Rough Country Budget Boost Question?????
