Rough Country 4' lift
Old 02-10-2009 | 11:27 AM
Dr.JK's Avatar
Default Rough Country 4' lift
I am looking at getting the Rough Country 4' lift complete!
Here is what it has, does anyone have this and are you happy with it?
Give me the pros and cons!
Front: Lifted coil springs, upper and lower control arms, track bar drop bracket, drop pitman arm, and brake line relocation brackets.
Rear: Lifted coils springs, upper and lower control arms, track bar drop bracket, sway bar links, and brakeline bracket.
Shocks: Kit includes (4) High Performance 2.2 series shocks.
Help so many lifts not sure what to do!
Old 02-10-2009 | 11:37 AM
Schantin's Avatar
4' or 4" lift
The 4' (4-foot) would probably require a lot of custom fabrication.
Old 02-10-2009 | 12:22 PM
Dr.JK's Avatar
4 inch lift
are you happy now?
Old 02-10-2009 | 01:09 PM
nclehmann's Avatar
Originally Posted by Schantin
4' or 4" lift
I saw this post earlier and was SOOOOOO tempted to write the same thing!! But I'm a nice guy!
Old 02-10-2009 | 01:10 PM
Dr.JK's Avatar
Thanks!
I am a little new here!
Old 02-10-2009 | 01:18 PM
Schantin's Avatar
I wrote it purely in jest....just couldn't help myself.
BTW, I'm new to Jeeps too. I've written sillier things on this forum..
Old 02-10-2009 | 01:32 PM
rodney's Avatar
With 4" you would need new drive shaft and if you going to add a 4" your going to most likely run 35's i would think with you would need to rear gear your front and rear.
Old 02-10-2009 | 01:59 PM
SiliconTi's Avatar
I just ordered this kit last night. It looks like a good deal if this is the last lift you are doing. If you plan on lifting higher, or doing some serious off-roading, this may not be the kit for you as the arms are all made specifically for this kit, meaning you'll have to scrap everything if you want to move on.
On a 4-Door, your shafts should be OK, on a 2-Door, you'll need a new front shaft at least, maybe both.
