Rough Country 3.5" Series II Suspension
Old 01-30-2013 | 05:41 PM
  #71
BADDANDY's Avatar
Be advised, I had to cut and reweld the pax side exhaust spacer to the same size as the drivers for mine to work. The joint wouldn't line up and hung below the crossmember.
Old 01-31-2013 | 02:49 PM
  #72
Jonathan_JK's Avatar
I'm not really worried about it. I'm having a 4x4 shop that does this work all the time. Actually when I went in there today to schedule a appointment they had a TJ that had the series II left just put on in the parking lot.
These guys do it all the time. I'm going to drop it off next friday morning at 8 and hopefully they will be done for lunch so I can bring them a few pizza's for the good work.
Old 01-31-2013 | 09:21 PM
  #73
BADDANDY's Avatar
I would take a look at it before you leave the shop. If it's below the crossmember, you should make sure those spacers are aligned in the pipe.
Old 02-09-2013 | 04:27 PM
  #74
I checked the underside out. It looks good. I don't think they had to weld anything.
Old 08-08-2013 | 03:41 PM
  #75
Dirt Addiction's Avatar
Originally Posted by Saharanewbie
Love mine. works perfect drives close to stock....
Is that the 2.5" or 3.5"? What size tires are those?
Old 09-26-2013 | 05:39 AM
  #76
Kojack's Avatar
Originally Posted by greensouth
I have this kit with AEV geometry brackets and its much better. No flightyness after the AEV install.
Thanks for posting, im going with this kit and RC's brackets. should see the same result.
Old 10-10-2013 | 09:05 PM
  #77
jshizzle's Avatar
Default Rear sway bar rubbing brake lines
I have this lift installed, but have noticed that the rear sway bar now rubs the brake line coupling where it goes from tubing to flexible hose. It looks like if I take off the bracket extensions it won't rub, but then I won't have the articulation. Is there anyone else having this problem?
Old 10-10-2013 | 11:46 PM
  #78
Tooadvanced's Avatar
Have had mine on my 13' for 15000 miles with probably 500+ offroad and dont have this problem
Old 06-13-2015 | 02:23 PM
  #79
matthewp097033's Avatar
Default Front and Rear Bumper
I just purchased a SmittyBilt Atlas front and rear bumper with tire carrier for my 2008 JKU. Can someone running a similar setup tell me if they lost alot of height due to the weight or are the springs stiff enough to not really notice? If so how did you counter this? Thanks in advance
Old 06-13-2015 | 04:13 PM
  #80
BADDANDY's Avatar
I wound up installing a 4" lift JKU right rear spring onto my 2 door JK. The bumper with tire carrier brought the rear down, especially the right considerably. Enough so that it raised the left front. All was good after I put the spring in. I have since removed the tire carrier and kept the bumper. She sits even L/R with the rear a tad up, which I like, so I can sit level with my trailer/pax/gear.
