Rough Country 3.5" Series II Suspension
#52
#53
#54
The ones that come in the kit are alittle longer than OEMs. To me they need to be alittle longer. I had to eventually order adjustables. Some people do without butane drove waaay better when the adjustables were installed. When you order check and see if RC will cut you a deal on some adjustables when you order. Good luck.
#55
My friend runs the RC 3.5 and I have the tereflex 2.5. Mine handles better and I still clear my 35's with room to spare. Although his off road capabilities are a little better due to the sway bar quick disconnects and better suspension travel.
#59
#60
I've been running this kit now for quit a while, only other suggestion that I would have to recommend is to add the coil spring locking taps to prevent them from twisting. I have had mine twist and when they twist it will allow them to come in contact with the rear trac bar.
