Rough Country 3.5" Series II Suspension
Just ordered mine along with quick discos, steering stab, exhaust spacer, and wheel spacers. Also picked up the AEV procal. Rock Ridge 4WD gave me a great discount and free shipping. I should be home in a week or two and will try the install myself in my garage. Hope for the best. You guys that did your own install is there anything i should look out for when doing it? Tips?
i just installed mine and I want to make sure I'm all good. so I have a few questions.
1. i bought the adjustable front track bar. so as i've read in other posts i did not install the drop pitman arm or the bracket. anybody else using this configuration? am i good this way or should i still install at least the bracket?
2. does anybody know if the grade 8 bolt kit from northridge still work on the RC control arms and adj. track bar? I'm thinking of getting it as an added piece of mind.
3. since i didn't use the track bar bracket. the steering stabalizer did not move. do i still need to move the bracket on the drag link over an inch as per the instructions?
anything else i need to double check?
