Rough Country 3.25 Lift with High Performance 2.2 shocks
#41
and for the money, you cannot get this type of product (lift/quality/and completeness) anywhere else. Not saying this lift is totally complete, but for the money, good value IMHO.
#42
I have had my 3.25" lift since December of 2009... now I have since added another 3/4" spacer and the jeep still sits lower than it did when I first installed the lift. I have not called the customer service about the springs, and I'm not sure if anything will be resolved after 10 months but I may give it a try. I called them once before and they replaced a few leaky shocks with an updated version without any hassle. The people at RC are very nice to deal with and both ordering and customer service.
#43
Just ordered my 3.25"
My lift should be here next week. I'll be out of town that week, but when I get back I will give my .02 on the lift install and ride. I'll be running it with 33's on a 2010 2 door sport.
Would be interested in seeing more pics if anyone else is running this lift with 33's.
#44
Lift is here...
I have received the lift and will be installing it this weekend. And, thanks to my wife, who let me purchase an air-compressor, the lift should go very smooth.
I will take some before/after specs and pics.
My Treadwright 285/75R16's should arrive on Monday and will be on Monday evening (I hope). So, it should be together no later than Tuesday.
#45
Before and After RC 3.25"
A few before and after shots... Wheels should be here this week and tires are in the garage.
Love the ride. Definitely better than stock. Would have taken pics during but ended up doing this solo. Not too bad as long as you have an air compressor.
John
John
#47
And for reference on the kit I'm referring to. https://www.jk-forum.com/forums/show...untry-3.5-lift.
#48
Not Really...
Otherwise, take your time and a 12 pack of Shiner and it shouldn't be a problem.
#49
Here is the progression my Jeep saw going from stock to the 3.25 RC lift to 37" tires.
Stock
3.25 RC lift on stock tires
3.25 RC lift on 37x13.50x17 Toyo tires
I didn't have any issues with the install or the instructions. I only needed the tool sizes that they listed. I have been running this kit for about 4 months now and have not had any issues. The ride was just a bit stiffer than stock, but changing the tires made more of a difference than the lift did. I have not had any issues with sagging, but I still have the stock front and rear bumpers on the Jeep.
Stock
#50
I have this lift on my 2010. I did not use the front brackets on the brake lines. I have not had any issues with the brake lines but I do not wheel it. I did use the rear brake brackets. I will get a front adjustable track bar along with lower adjustable control arms later this year. It will just make it ride better.
The ride has been fine and I have put about 5K miles on it in the 4 months it has been in. I notice no sagging as yet and the ride is a little stiffer than stock / new.
It took me about 5 hours with another person. Directions, when I read them were very clear and good. This is not my first lift kit but it was the most complete kit.
I used 17x9 MT wheels with the suggested 4.5 - 4.75 backspacing and have had only slight rubbing on the airdam which I trimmed off.
I did not need to lengthen driveshafts but then again, I have not wheeled it and fully extended the axles. I do not think I would have an issue even if I went to full droop.
Hope this helps.
Mandor
Hope this helps.
Mandor
