Rough country 2.5'' with OME LT shocks?
has it been done? is it possible? and if so are there any pictures. i will be taking off the shock extensions/relocating brackets. let me know what things i should be worried about.
Not going to hurt a thing!
OME's lift is the same advertised height (although you actually net about 3"). Are you going with springs or the spacer kit? If springs, the OME shocks will help with the ride quality of the RC springs. If you are going with the spacer kit ride will be on par or slightly better than stock.
OME makes a really good shock IMO.
![beer](https://www.jk-forum.com/forums/images/smilies/beermug.gif)
i went to azusa canyon ohv and after i got home and taking it to the dealership we figured out i messed up my front shocks. so now i need to replace them asap. now i want a shock that will give me more droop and that wont cost me an arm and leg. ANY SUGGESTIONS? OME LT SHOCKS $83. SUGGESTIONS.
just for now im going to get the front shocks because those are the ones that i messed up.
BUMPSTOPS i have 2" body lift pucks that i can cut down and make my own bump stops to eliminate me blowing them out.
BRAKELINES i have a set brakelines that are for a 4-6in lift
the one thing im worried about is blowing out the shock. so i might need the compressed shock lenght for STOCK AND OME LT shocks. can anyone help me here.
now remember with the RC 2.5in BB the spacer went above the bump stop. so wouldnt that be like adding a longer bump stop.
