Rough Country 2.5. " lift. Springs and shocks
Throw money at parts that may or may not help the issue instead of getting the alignment specs to see where you're currently at. Makes sense!
Start with the numbers. Then research the different forms of caster correction. You might decide on arms instead of brackets.
I have the same setup and properly inflating (which in this case was DEFLATING) my tires made all the difference in the world. I was running too much pressure in my Dick Cepek 35's... after airing down to just under 29 psi at all four corners it solved my swerving. What PSI are you currently running? I'm on the RC 2.5" setup, Mickey Thompson Classic 17's, Dick Cepek Fun Country's and a synergy adjustable track bar.
So I installed my adjustable track bar yesterday and the jeep does handle alot better. Axle is perfectly centered to the frame.
Today I'm going to drop the tire pressure from 36 to 30.
I'll let you know tomorrow how it feels.
I am getting a little squeakiness coming from the front which I didn't gave before. Bolts tightened to 125
